Racetronix Install Question
I'm in the process of putting the new pump in, and ran into a semi-snag suddenly.
The racetronix directions say to basically to put the stock connector on to their harness. Red and grey wires on their harness, you have to remove the black and grey and purple wires on the stock harness.
The harness I have has two connector ends. The one end connects to the pump, with a black wire with an in-line spade and a white wire. The other connector is exactly like the stock one on the car. Do I just need to remove the purple wire from the stock one and put it into the Racetronix harness, thus eleminating all of the old wiring harness, or am I missing something?
Re: Racetronix Install Question
Originally Posted by Racetronix
Did you get our reply email?
Sure did. Is Racetronix sending out two different styled harness' or are you moving from one style to another?
Same thing happend to me, im actually waiting overnight for the bucket to seal properly. I need help fast on that same thing. Should i take the old wire and plug it into the new harness? whatmods@hotmail.com <---my email
Simply transfer over the violet wire if your pump already has a connector on the end of it. We started putting the connector on the end because a few people reversed the polarity of the pump.
Instead of guessing just e-mail support@racetronix.com.
Well the car is up and running but there is a problem, The gas level goes way over the full position, Ive taken the pump out twice to see if there was anything in the way of the level sensor but nothing. Could it be that the violet wire is not properly connected? Could this cause the level sensor to not work?
Did you plug the Racetronix black ground wire's female terminal into the top of the level sender?
yes the racetronix black wire is connected to the top of the level sender, ill try sanding the old terminals a bit since they are a bit rusty looking. ill come back with some feedback
wow what a coinsicence. Yup just finished taking the pump off and saw that the pin had come off the terminal. it had almost no slack so i added about 2 inches of wire, welded them and now it works!!! Thx guys especially racetronix. Now to go test it out!!!
Welded?
