Quick question on head bolt torque!!!!!!!
My chiltons says 22in-lb which has to be wrong for 96-97 LT1's. Its says 65lb-ft for 93-95 LT1's. I am currently putting a head back on a 96 z28 and want to know what I should torque to. Should I do 65lb-ft like the 93-95's? need help quick. Thanks.
Re: Quick question on head bolt torque!!!!!!!
That would be 22 lb. ft. before adding the required angle torquing. (additional 67º for the short bolts and 80º for long and intermediate bolts)
You would need a torque angle meter similiar to this http://www.thetoolwarehouse.net/shop/LIS-28100.html to do that. I just torqued my heads to 65 lbs. in 3 increments 20,40,65 lbs. using a standard torque wrench.
Kenny
Kenny
Originally Posted by KenP
You would need a torque angle meter similiar to this http://www.thetoolwarehouse.net/shop/LIS-28100.html to TTY. I just torqued my heads to 65 lbs. in 3 increments 20,40,65 lbs. using a standard torque wrench.
Kenny
Kenny
Kenny
Kenny
