Possible to install cam bearings without the tool?
Old 02-28-2008, 06:11 PM
Z28LT1_Just_Nasty's Avatar
Is it possible to remove and install cam bearings without the special cam bearing installation/removal tool? This is with the block completely disassembled. I can't justify buying the tool if I'm only going to use it once (its pretty much the only tool I don't have)
Local machine shop is backed up and I'm on bit of a tight schedule to get the car done before my vacation is up otherwise I'd take it to them. So if anyone has any ideas I'd like to hear them.
Z28LT1_Just_Nasty is offline
Old 02-28-2008, 06:15 PM
mdacton's Avatar
no
I would call the machin shop, tell them you will pay cash and help move the block etc. It will only take a few min. they need to be perfectly straight. If you have never done them you need someone else to do it.
I can put them in in a few min....take your cam with you and oil it up stick it in and make sure it turns nice and free before you leave.
mdacton is offline
Old 02-28-2008, 06:25 PM
marshall93z's Avatar
+1
marshall93z is offline
Old 02-28-2008, 06:54 PM
shoebox's Avatar
You might be able to do the two outside bearings, but not the inside ones. The tool makes it pretty easy. If it was the 'only tool I didn't have', I would buy one.
shoebox is offline
Old 02-28-2008, 07:09 PM
96capricemgr's Avatar
I did a front one without the tool on a weekend in a big bind. Even that one was a hassle.
The tool is a lot cheaper than the consequences of getting it wrong.
96capricemgr is offline
Old 02-28-2008, 09:38 PM
It's pretty easy if you have the tool. I did mine and had never done it before. Didn't take long at all.
Old 02-29-2008, 03:58 AM
SS RRR's Avatar
I tried this on the front bearing of a friend's car with a flat piece of plastic by banging around the circumference in a circle and could never get one in straight. I haz no skillz!
SS RRR is offline
Old 02-29-2008, 04:59 AM
CANTONRACER's Avatar
My machine shop charged me $10 to put in the bearings....and the cost of the bearings.
I let them do it and I even have the tool and have done it dozens of times.
CANTONRACER is offline
Old 02-29-2008, 12:02 PM
$10 is cheap!
Old 02-29-2008, 12:05 PM
mdacton's Avatar
Originally Posted by marshall93z
$10 is cheap!
I think most places charge around $35-$45 + the bearing price
mdacton is offline
Old 02-29-2008, 02:04 PM
Geoffmj's Avatar
Sorry I dont meen to hijack the thread but since we're on the subject of cam bearings I was wondering if it is possible to remove and install cam bearings with the crank still in the block?
Geoffmj is offline
Old 02-29-2008, 03:01 PM
I paid $30. Ended up doing them again myself.
Old 02-29-2008, 03:03 PM
Ya I figure I might as well just buy the tool. I know more than likely someday I'll use it again or at least sell it. Thanks for the replies.
Old 02-29-2008, 03:09 PM
mdacton's Avatar
never tried it...but its not that hard to go ahead and take it out....
Trying to cut corners always ends the same way
mdacton is offline
Old 02-29-2008, 03:17 PM
shoebox's Avatar
The crank should not interfere, but the engine has to be out of the car.
shoebox is offline
Quick Reply: Possible to install cam bearings without the tool?
