Need to Extend the Intake Elbow
Old 02-29-2008, 12:38 AM
Counted Out's Avatar
I bought a Moroso Cold Air Intake for a 94-97 LT1 and my car is a 93, therefor it is about 4" short (I don't have a MAF). I was thinking of keeping 4" of the Stock Air tubing connected to the elbow and connecting the Cold Air Intake to that. But what would be the best way to connect the tubes and keep them air tight?
I think someone recommended a silicone sleeve, but I wouldn't have a clue on where to find one of those.
Edit - Got it.
Had to put a small piece of PVC on the left inside the rubber joint. Seems like it will work perfect.
Counted Out is offline
Old 02-29-2008, 12:46 AM
Ironxcross's Avatar
could just get a 3" diameter 4" long tube and get some connectors for it. I'm thinking home depot or something here.
Ironxcross is offline
Old 02-29-2008, 03:14 AM
ss.slp.ls1's Avatar
PVC pipe and some clamps.
ss.slp.ls1 is offline
Old 02-29-2008, 01:46 PM
BUBBA's Avatar
You can find one at Home Depot or just about any place that carries plumbing pipe.
BUBBA is offline
Old 02-29-2008, 03:05 PM
Moderator
97ChameleonTA's Avatar
Go to Lowes and get a piece of septic piping or a coupler. It is already black in color and made from ABS plastic which has a higher heat threshold than PVC. You can also pick up a Fernco rubber coupler for the extra connector.
97ChameleonTA is offline
Old 02-29-2008, 04:19 PM
I think I'm going with that one. I'll post pictures soon.
Old 02-29-2008, 04:22 PM
byrons1502's Avatar
i use the diesel shop for hose and clamps. 3" exhaust pipe is cheap
byrons1502 is offline
Old 02-29-2008, 10:24 PM
BigBadBlack93Z's Avatar
buy a stock maf, cut and smooth the center section. they're like $8 on ebay
BigBadBlack93Z is offline
Old 02-29-2008, 11:28 PM
Old 03-01-2008, 12:06 AM
Ironxcross's Avatar
nice work.
mightymouse383
07-20-2016 07:34 AM
Fatdog2
06-13-2015 11:18 PM
DirtyDaveW
03-15-2015 07:01 PM
slothgrant
08-22-2002 03:01 PM
Quick Reply: Need to Extend the Intake Elbow
