Plug Gap Setting
Old 06-26-2014, 03:47 PM
cdubya's Avatar
Plug Gap Setting
Howdy Partners
I am replacing the old AC iridium plugs with some standard NGK's.
Can anyone tell me the correct gap setting for these thanks, they are not Iridium ones.
Cheers
cdubya is offline
Old 06-26-2014, 04:00 PM
Re: Plug Gap Setting
LT1 stock gap is .050".
Note that it is also beneficial to provide a signature with some car info, so people know what vehicle they are replying about.
shoebox is offline
Old 06-26-2014, 10:21 PM
Kevin Blown 95 TA's Avatar
He's right, of course, but consider a gap of .045 since the gaps will open up with use, and as much of a pain as they are to change, you can buy some extra miles of use that way.
Kevin Blown 95 TA is offline
Old 06-27-2014, 08:26 AM
A good reason to stick with Iridium plugs, for anything other than a big "power adder" setup (forced induction or nitrous). I can't think of any advantage in using a non-precious metal plug in a normally aspirated application. I run conventional plugs, but only because they get changed frequently switching between street driving and 300-shot track use (at least when the car actually used to get driven).
Injuneer is offline
jayblev95
East South Central
02-15-2015 02:26 PM
1963SS
02-06-2015 10:05 AM
jayblev95
01-06-2015 11:52 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Plug Gap Setting
