Overheating problem
Overheating problem
Hey guys, i own a !996 Z28 and im having a little trouble. My car is over heating, and can't figure out what the problem could be, I have replaced the Radiator car, Did a pressure test and it holds just fine around 16 PSI, i did a block test to see if i had a blown head gasket or something along those lines and all was good, The therm, looks good, I am stuck. I looked at the fuel pump and it looks ok aswell, All the hoses are fine. and there are no visable leaks. Please help me out! I've done everything i can to figure this out and i am lost!
Re: Overheating problem
Please describe the symptoms/conditions/temperatures in detail.
Cooling system operation and testing
Dan_the_ManZ28
02-21-2015 02:01 PM
