Overflow grommet
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Overflow grommet
This one might have what you need: http://www.ebay.com/itm/93-02-Camaro-Z28-Firebird-Trans-Am-WS6-Coolant-Recovery-Tank-Reservoir-/371301843929?hash=item56735083d9&vxp=mtr
This one might have what you need: 93 02 Camaro Z28 Firebird Trans Am WS6 Coolant Recovery Tank Reservoir | eBay
Maybe seal the grommet by applying RTV to both edges.
Just a thought - why would coolant be leaking at the top of the container? Overfilled? Shouldn't be possible.
V8 and V6 overflow/battery trays are identical... no need to limit your search to V8's.
thanks you guys for your help
I may try the RTV bc its not leaking more like a small pool of ANTIFREEZE sitting in the hole on top of grommet where the tube inserts if you get what im saying ?
no its the grommet I changed the hose and rubbed a little lucus trans slip on it and it has worked to the point there no air in my system any longer but it just has a little
water on top
water on top
