Overflow grommet
#16
Re: Overflow grommet
It is not uncommon for the metal hose to leak. Battery corrosion causes holes in it. As I see it, there would be no reason for coolant to be on top of the grommet unless there was a leak above the grommet.
#18
Yea bro it's gotta be a hairline leak, my oil cooler hose did the same thing n I couldn't find the leak till iv swapped the hose and found a very small crack in the hose lol,I'll get u that piece or reservoir bottle when I go to wreck yard
#19
Ok so I found out where the air is coming into the system it's coming from the pit **** at the bottom of the radiator now can I change that or do I need a new radiator ? And would this make my overflow push water out
#20
Hey bro change the pit piece n see wat happens n monitor the coolant level,if ur radiator is not cracked or leaking I wouldn't mess with it.
#23
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
#30
Are you sure you have the hoses correctly routed/connected? Mixing up the overflow and the steam pipe causes problems.
http://shbox.com/1/radiator_A4.jpg
