Overflow grommet
Old 05-07-2015, 09:36 PM
  #16
Re: Overflow grommet
It is not uncommon for the metal hose to leak. Battery corrosion causes holes in it. As I see it, there would be no reason for coolant to be on top of the grommet unless there was a leak above the grommet.
shoebox is offline
Old 05-08-2015, 01:12 PM
  #17
blac94Z's Avatar
that makes sense but there must be a crack that I cannot see on the metal hose or it must be hairline
blac94Z is offline
Old 05-10-2015, 06:56 PM
  #18
94Z28LS1toLT1's Avatar
Yea bro it's gotta be a hairline leak, my oil cooler hose did the same thing n I couldn't find the leak till iv swapped the hose and found a very small crack in the hose lol,I'll get u that piece or reservoir bottle when I go to wreck yard
94Z28LS1toLT1 is offline
Old 05-28-2015, 07:26 PM
  #19
blac94Z's Avatar
Ok so I found out where the air is coming into the system it's coming from the pit **** at the bottom of the radiator now can I change that or do I need a new radiator ? And would this make my overflow push water out
blac94Z is offline
Old 05-28-2015, 08:11 PM
  #20
Hey bro change the pit piece n see wat happens n monitor the coolant level,if ur radiator is not cracked or leaking I wouldn't mess with it.
Old 05-29-2015, 12:02 PM
  #21
blac94Z's Avatar
I want to know if we can change the pit **** before I pull it out , or if I should just get a new radiator
blac94Z is offline
Old 05-29-2015, 02:56 PM
  #22
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Is this site censoring the word "pitcock"?
GaryDoug is offline
Old 05-29-2015, 03:07 PM
  #23
Prominent Member
GaryDoug's Avatar
This what you need?
Dorman/Radiator Drain Plug 61136 at AutoZone.com
GaryDoug is offline
Old 05-29-2015, 04:23 PM
  #24
blac94Z's Avatar
yes that is what I need the butterfly part I guess is broken and it leaks water out very slow
blac94Z is offline
Old 05-29-2015, 04:24 PM
  #25
Only if you incorrectly spell it as two words......
petcock
pet ****
Injuneer is offline
Old 05-29-2015, 04:38 PM
  #26
blac94Z's Avatar
i think you have to put them together lol pitcock
blac94Z is offline
Old 05-29-2015, 04:43 PM
  #27
blac94Z's Avatar
so would this be making my coolant push out of my overflow ?
blac94Z is offline
Old 05-29-2015, 05:52 PM
  #28
The word is PETCOCK.
Injuneer is offline
Old 05-29-2015, 06:09 PM
  #29
blac94Z's Avatar
really thanks for updating me on that so anyone will that stop my overflow from pushing coolant out the top ?
blac94Z is offline
Old 05-29-2015, 09:40 PM
  #30
Are you sure you have the hoses correctly routed/connected? Mixing up the overflow and the steam pipe causes problems.
http://shbox.com/1/radiator_A4.jpg
shoebox is offline
Quick Reply: Overflow grommet
