Optispark Front Cover Oil Seal Question
I did a cam swap a couple of months ago and replaced all of the seals on the front cover. The oil seal for opti started leaking almost immediately, about a drop of oil a day. I pulled it out today and really can't see anything wrong with it or the sealing surface on the opti. I'm getting ready to replace the seal again - are there any special precautions that I might have missed?
Re: Optispark Front Cover Oil Seal Question
and the Opti and WP dive seal are PTFE...they install dry. Do not lube them
typically the leak is from the WP drive gear as on install it is easy (especially when not using a install tool) to fold over the inner lip which is a instant leak. Oil migrates down and it can appear the Opti or crank seal is leaking when in fact the WP drive seal is the problem. Look carefully when you remove Opti
Oncomingstorm22
01-22-2015 07:15 PM
crazypurgatory
01-12-2015 10:45 PM
