silicone hose for EGR?
Re: silicone hose for EGR?
The typical upper limit for high temp silicone hose is 500*F. Exhaust gas can easilly reach 1,000*F.
Why silicone? What's wrong with the stock corrugated metallic tube? If you are concerned about heat affecting the intake manifold rear RTV seal, put some insulation on the tube.
