Oil leak (Front of oil pan)
Re: Oil leak (Front of oil pan)
Brake cleaner or carb cleaner can be your friend, clean it good and then drive it look where leak is coming from. Front engine oil leaks can be from pan, water pump drive seal, opti seal, crank seal or front of intake.
Don't waste your time with those cork thing a ma bobs. Put some black permatex on the front and the back and be done with it for good. We always have problems with the cork crap but never when replaced with Permatex.
When i swaqpped the cam out in my car i ripped the front of the oil pan gasket, made a new one out of copper RTV. Worked great. Now when i rebuilt the engine i wanted it to look nicer so i used a new oil pan gasket (plus i had two brand new ones here so why not)...well guess what now i have a leak from the front of the oil pan Sometime i need to jack the engine up a few inches and drop the pan and put some RTV in there or something.
Used the red stuff worked fine. no leaks sense. It has a higher tolerance then the black stuff that came with it. But just had tube of it around. Made some scratch marks liberally on the front and abck and wasn;t stingy with the red high temp RTV. So far so good and pleased.
Magenta_Hearts
03-29-2017 08:54 PM
