oil leak
Old 06-08-2016, 07:27 PM
frankrizz's Avatar
oil leak
Hey Members, I have a very slight oil leak at the front crank snout seal. A felpro seal was installed about 6 months ago. At idle everything is bone dry.
After a short drive I notice a small weepage of oil. I know the front pan seal is not the problem. Is there any chemical fix for such a leak. I really do not want to have to pull the snout if possible.
frankrizz is offline
Old 06-08-2016, 09:01 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: oil leak
I used this stuff to stop a rear seal leak on my LS1 engine about a year ago. It's leaks about 90% less now. They claim it works on front seals too.
Rear Main Seal Stop Leak | Rear Main Seal Leak Repair | BlueDevil
GaryDoug is offline
Old 06-10-2016, 10:00 AM
Chimera96's Avatar
Re: oil leak
rare the crank seal leaks. more typical is WP drive seal. The oil drips/migrates down to the lowest point and can appear to be coming from crank seal
are you sure it is your front crank seal leaking?
Chimera96 is offline
Old 06-10-2016, 01:34 PM
timnfxr's Avatar
Re: oil leak
As stated, the leak may be originating much higher than the crank seal. Try using oil/fuel/ATF dye in your oil, run engine to operating temperature, then with engine off inspect using UV light and glasses. That should localize the highest point of the leak.
I've used this in the past and it proved valuable.
Typically it's the WP drive seal that leaks.
timnfxr is offline
frankrizz
12-16-2015 05:11 AM
frankrizz
11-21-2015 05:50 AM
frankrizz
11-15-2015 06:08 PM
95_Z28/SS
05-20-2015 01:23 PM
Nickster 7
05-01-2015 09:04 PM
Quick Reply: oil leak
