need valve cover breather suggestions...
I'm trying to find a valve cover breather for my new valve covers and can't seem to find one. Will the Autozone one that they have out on the shelves work? It says that it is for a SBC. I assume this is a standardized size thing. One more question is, does the oil fill tube from the stock covers fit into the new chrome ones that I have?
The part number for these is 141-130... they are 1/4" taller than stock. Thanks guys.....
Re: need valve cover breather suggestions...
Originally Posted by SILVERZZ28
I would suggest keeping the stock breathing system! Letting in/out unmetered air can cause the car to run different
i just capped the hose from the passenger side valve cover and plugged the tb, so really theres no point in having hte pcv valve anymore, right?
can i just remove the pcv valve, and the hose attached to it, and plug both holes?
I think he meant if you put on a breather and kept the pcv system in tact, then you would have unmetered air entering the intact tract. If you remove the pcv hose and cap the throttle body when using a breather you wont have a problem.
Since i have the AZS&M Monoblade, i can just get a breather for the pass VC and remove the hose that hooked up to the stock TB without any troubles cant i? Let me know if im wrong.
Brandon
Brandon
Speeds8erM-1
07-28-2002 06:18 PM
Speeds8erM-1
07-18-2002 11:36 PM
