Straight pipes(true dual) vs Cat back Corsa
Old 09-21-2011, 08:14 PM
bencher's Avatar
What would be the advantages/disadvantages of having stock exhaust manifold going to dual pipes and out high flow mufflers, as oppossed to stock exhaust manifolds to off road y-pipe to Corsa catback(though no cat) exhaust? As in, would the drop in back pressure be of any effect with the true dual exhaust? I plan on going to shorty headers soon, so either system would be easy to just bolt to the shorties.
bencher is offline
Old 09-21-2011, 08:34 PM
94Zee28's Avatar
Re: Straight pipes(true dual) vs Cat back Corsa
Unless you need the clearance, I would go long tube headers with 3" off road y pipe into a 3" cat back exhaust. Better low end torque and I think easier to bolt up vs the shorties.
94Zee28 is offline
alphaauto
01-22-2015 08:02 PM
joffer00
Exhaust System
12-22-2014 03:25 PM
Queens94z28
11-20-2014 06:03 PM
RedLineRev
01-23-2003 03:51 PM
Quick Reply: Straight pipes(true dual) vs Cat back Corsa
