My horn/lighter fuse keeps blowing out
Every time I put a new 25 amp fuse it blows out when I press the horn. I seem to think a mechanic once said, after working on my car, that I had two horns and he disconnected one??? I didn't know what the hell he was talking about then, but I think that what ever he did might have something to do with it.
What would cause the fuse to blow out every time? Could it be a loose or disconnected ground wire?
The dual horns are up in the front of the passenger side fender, near the coolant reservoir. The horns are wired in parallel, so removing one of them would not increase the electrical load, it would reduce it. I have one removed. There is a relay for the horn, with a diode in it according to the Chilton's wiring diagram... perhaps the relay is shorted.
Horns
Horn relay
Horn schematic
Try unplugging your horns and see if the fuse still blows when you try to honk (no, it won't sound with the horns disconnected, but the relay should engage and send power to the horn harness). A fried horn might cause the fuse to blow.
Horn relay
Horn schematic
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
