lt1 starter to block bolt size????
Old 08-06-2006, 04:57 PM
diamondhill's Avatar
Question lt1 starter to block bolt size????
does any one know the bolt size to a 1995 lt1 engine????? what size thraed,pitch,length????
diamondhill is offline
Old 08-06-2006, 05:03 PM
ABA383's Avatar
Re: lt1 starter to block bolt size????
I don't know the sizes off hand, but if you are replacing the bolts you need to get actual starter bolts. They have some knurling on them and are set up to properly align the starter in the block...Regular bolts don't do that...They are not cheap from the dealer, and Advance Auto sells them , too...
--Alan
ABA383 is offline
Old 08-06-2006, 05:15 PM
Moderator
Javier97Z28's Avatar
Any auto parts store should have the correct bolts.
Javier97Z28 is offline
Old 08-06-2006, 06:53 PM
i found some at autozone, the ones i saw were a 3/8 16 should i get them they are starter bolts
Old 08-06-2006, 07:30 PM
3/8-16 should be right.
shoebox is offline
Old 08-07-2006, 01:13 PM
thanks for the help fellas
HectorM52
07-30-2017 11:46 AM
ChrisFrez
01-11-2015 03:47 PM
Jeff1904
01-03-2015 12:00 AM
Dyoung_Z28
11-25-2014 05:26 PM
07-04-2005 05:00 PM
Quick Reply: lt1 starter to block bolt size????
