MTI Heads - Valve Spring Question
Does anyone know what kind/size of valve springs came on the MTI Stage 2 LT4 Heads? I snapped one, I need to get new springs, but I'm not sure exactly what is on there...
Re: MTI Heads - Valve Spring Question
Originally Posted by Z95m6
If you snapped the valve spring don't you think you should upgrade rather than put the same stuff on and have it happen again. Just a thought.
Unless they are out of business or something, call where you got the fheads. Or check the documentation you got, the specs whould be there. Or, if those options don't work, any decent engine shop will have a spring tester and a set of dial calipers. Take them a "good" spring and ask them to measure it and test it. The numbers you need are the spring height (free and compressed), the rate, and the ID and OD. Then you can get a comparable spring.
However, why did it break? Are they worn out, is there another problem?
Rich
Rich
oldschool
02-09-2016 09:21 PM
