Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > LT1 Based Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 12-10-2004, 12:55 PM   #1
MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
I thought that maybe someone will be happy to see this. We waited so long for something like this(but not for ($500) and here we have...
OPTI
Sebastian
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
Jaguar XFR (RSC package) ~500HP
C3 Vette ~500HP
Buell XB12S
scyzoryk is offline   Reply With Quote
Old 12-10-2004, 01:12 PM   #2
Re: MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
I have sen those and the only thing i dont like is that its not the whole opti unit, just the cap and rotor. i do however think that is cheaper than the estimate that they gave me on a stock replacement cap and rotor at advance.
__________________
02 Silverado 5.3 2x4 - LT's - Super 44 - 3.73's - Homebrew CAI
97 Trans Am LT1 355/TH350 - CC 503
05 SRT4
Evil Eric is offline   Reply With Quote
Old 12-10-2004, 01:39 PM   #3
It has been awhile since I changed mine. What else do you need. I was thinking everything else inside you could reuse. I really can't see why they would sell this piece if you still needed other parts. BTW its only $151.99.
__________________
95 Z28 Black 6-speed Hypertech Programmer w/cartridge, Moroso Cold Air Intake, Smooth Bellow, LPE Ported Intake, Adjustable Fuel Pressure Regulator, Magnacore Wires, Edlebrock Headers, High Flow Cat, Borla Cat-back, Hurst Shifter, Spec Stage III Clutch,Transmission Rebuild by RPM, Bilstein Shocks,Eibach Pro Kit,HPM 4 Point Strut Tower Brace, HPM Sub-Frame Connectors, HPM Trailing Arms, HPM Panhard Rod Bar,HPM Adjustable Torque Arm,Poly Bushings, Hellwig Sway Bars,Richmond 4.10s,Torsen Zexel Diff
SVWHAT is offline   Reply With Quote
Old 12-10-2004, 02:32 PM   #4
Super Moderator
Garage
Quote:
The Opti has 2 "halves" - BOTH of them can fail. The front section is the cap and rotor. The back section is the housing, including the bearing (low quality, wears out), the optical sensor and rotating "disc", and the seal for the harness connector, which is the primary "leakage" source. The cap/rotor represents the bulk of the failures, but in maybe 20-25% of the cases, the optical sensor gets crudded up with rust from the cheap carbon steel bearing retainer plate, or the bearing wears out. Replacing only the cap/rotor on a high mileage Opti is risky.
__________________
Fred
94 Formula A3+1: 381ci all-forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons/CNC LT4 heads/Comp Cams custom solid roller/TH400+GearVendors OD/4.11's/Strange 12-bolt/300-shot N2O/Spohn Suspension/6-pt roll bar with integrated SFC's/full AutoMeter instrumentation/MoTeC M48 Pro engine management system/a few other odds 'n ends.
My website is down. Hopefully, links/photos be restored in 2 or 3 weeks.
Injuneer is offline   Reply With Quote
Old 12-10-2004, 02:53 PM   #5
Advanced Tech Moderator
kmook's Avatar
http://web.camaroz28.com/forums/showthread.php?t=315840
And as said it's just the cap and rotor...
__________________
-Ken Mook
kmook is offline   Reply With Quote
Old 12-10-2004, 02:56 PM   #6
Super Moderator
95 Z/28 LT1's Avatar
JMO, but I doubt it's much better than the stock one.
__________________
1995 Camaro Z28 Convertible
2008 E63 AMG P30
2010 BMW X5M
95 Z/28 LT1 is offline   Reply With Quote
Old 12-10-2004, 08:19 PM   #7
Quote:
OPTI
Sebastian
Your kind of late to the party. This has been posted by numerous people for several weeks, now.
I don't see where a cap and rotor is much to get excited about.
shoebox is offline   Reply With Quote
Old 01-28-2005, 10:02 PM   #8
DavesLT1's Avatar
Send a message via Yahoo to DavesLT1
just wondering if anyone has tried this yet. and if so, how did it work?
__________________
1997 Z28 M6, with Morroso CAI, ported 52mm TB, air foil, !CAGS/EGR, 1LE intake elbow, Borla cat back system, MSD 6A and blaster coil, 160* t-stat.
1967 Ford Galaxie 500: 460 big block, TCI Super Streetfighter A4, custom 2" headers, custom 3.25" true dual, dual flowmaster 40's, Edelbrock Performer RPM manifold, cam and heads, Thunder series 800 cfm carb, Carter fuel pump, MSD blaster 2 coil, billet distributor and 8.5mm wires. hoping to get over 500 HP
DavesLT1 is offline   Reply With Quote
Old 01-28-2005, 10:11 PM   #9
turbo_Z's Avatar
It looks like they improved the rotor tip design with a plastic retainer and solid metal rivot. That IMO was the weakest link in the opti.
I may buy one next month to check out but I probably wont be installing it since my opti is only a couple months old.
__________________
Brad
1997 Z28 M6
340rwhp/340rwtq(before LE heads)
mods: loud exhaust and lopey idle
turbo_Z is offline   Reply With Quote
Old 01-28-2005, 10:31 PM   #10
DavesLT1's Avatar
I might get one and replace my opti at the same time just to be sure as I have no clue as to how old my opti is, and my car has 78k on it.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
