What springs to use
Old 01-27-2005, 04:15 PM
Zachz28's Avatar
What springs to use
What springs should i use with 1.6rr and CC305?
Zachz28 is offline
Old 01-28-2005, 12:56 AM
sssalah's Avatar
Re: What springs to use
Many choices:
Comp recommends 986-16
crane 10308, comp behives and cms will work.
sssalah is offline
Old 01-28-2005, 09:56 PM
Zachz28's Avatar
can those springs be used with only 1.6 rockers untill i put the cam in or will they be too strong
Zachz28 is offline
Old 01-28-2005, 10:23 PM
sssalah's Avatar
Some stick with the stock springs when going to 1.6, but that's on the edge. Yes you can use any of these springs with a stock cam, seat pressures are modarate. The best springs to go with are the behives, they'll give you spces to grow on cam choies and offer the best stability at high revs due to the reduced mass.
sssalah is offline
95z28man7
N2O Tech
08-16-2015 10:58 AM
9t4lt4z28
Parts Wanted
07-19-2015 06:16 PM
Z28amustangklr
07-18-2015 11:05 AM
Catmaigne
07-14-2015 05:17 PM
Quick Reply: What springs to use
