reducing knock sensitivity on a 93
Just in case you didn't know about this site, it good for the 93s.
http://sdf.mogmhp.com/
wow both really great sites thanx guys, i also found http://www.geocities.com/MotorCity/6647/ta93/knock.htm for any future searchers.
But the reason i am doing this is because i just installed a cutout and i am getting majour vibrations from the deep rumble, i am really afraid this is causing false knock, i never use octane below 91 and for the past 3 weeks since fuel prices have been low i have been using 94 octane only. So i doubt i would have any real knock!
Knock Sensor... (shoebox's picture)
nice thnx, ok i think i have found the blue wire, its in one of them wire coduits, but just to make sure i dont cut the wrong thing can you tell me what other wires are in the conduit with it so i know if i opened the right one?
There should only be one wire going to the knock sensor, and the timing should adjust right away. When it is pulling timing if it detects knock, it does it only for as long as it detects knock and then immediately goes back to normal.
Nayr
03-03-2023 08:34 PM
