Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
I need to install some sub frame connectors soon. I had my car up on the lift, got a good look at the frame and started thinkin. I cant really see it being that hard to buy some steel tubing/plates and bend and weld up my own sub frame connectors. As a matter of fact, that goes for the strut tower brace as well. I work in a dealership shop and have plenty of equipment to get the job done. I just don't know if I'll screw something up. I figure doing it this way, I would be able to make them bolt up 1st, see how they feel, throw it on the alignment rack to check for F-up's, then weld them in if everything is peachy. I don't really care about how they look under the car( I'll worry about that when I'm pullin the front wheels 3 ft off a launch). I'm planning on taking up metal fabrication soon anyway. Just an idea. What do ya'll think? I'm trying to get as much input as possible. Thanks!!!
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
__________________
Cmbob67
94 Trans Am A4 (KikinWing) Custom Made 3 1/2" CAI w/ K&N, Custom made Strut Tower Support, Ported & Polished MAF, 1LE Elbow, MSD 8.8's, A.C. Delco Dbbl Platinums plugs, Flowmaster, T/B Bypass, 160 Thermostat, n'stuff.
Might be a good project. Couldn't hurt to try. Good luck!
Oh, but you may want some advice for the future. If you do this and it works good, you must document every procedure/materials used/cost, b/c if you make posts without telling your "secrets" or "custom work", people will get mad at you.
...just a joke, but seriously, good luck, it's definitely something I haven't heard of people trying to do.
you must also swear to the LT1 gods and post dyno results immediately,
Anyway I have a frwind that has made his own, just be sure to have the weight on the suspension when you weld them in. (I.E just like it was setting on it tires fully)
__________________
Perry,
97 WS-6 T/A, 11s without sweating.
383 ,AFR heads, GM847 cam,LT hookers Mufflex Y, 3000 vig,3.73s ,and various other mods.
Yea, I know. There has been a bit of S-Talking on the old site here. Com'on fellas, Were all buddys here. Anyway thanks for the incouragment AxeGrinder!! I will make it a point to photograph and document every move. Thanks !!!
__________________
Cmbob67
Originally posted by WS Sick you must also swear to the LT1 gods and post dyno results immediately,
dyno results?
I know it can be done, but just gotta cost it out and see if its a better option of taking the materials and the chance that it doesnt work out or something...Then you'll be down that much more money when you go out to buy some Kenny Brown's or bmr'S..
But it sounds like a good project! Keep us posted if you do try!
__________________ 1994 "Teal Terror " Z28 & 1984 TA R.I.P-2/3/03 Teal Terror's Website The TA Got Me Hooked On Speed
Talk LT1s W/ Me AIM:Chesee48
Project 84TA/LT1 Has Begun 11/17/03 Itssssss's Back!
Project 94Z/383 Forged Stroker Has Begun 8/25/03
C U B B I E S MADDUX 300 and COUNTING!
94 Z28 <383 in the works>
84 TA <gone>
99 Grand Am GT <Daily Driver>
Excellent idea, in fact I laid a plan out w/drwgs for mine using square tubing same size as BMR's square. I like their design because it beefs up the LCA brackets. Mine is being modified to have stitch welds in between the length front to rear is the major difference. Rather than just being connected front and back they will also be attached throught the length for rigidity. $23.00 for materials from our local steel supply.
I put a set on my buddies TA that you could make very easy. they were just straight pices of boxed tubbing probally 1.5"X3 and I don't rember how long they were but they had great ground clearance and every easy to intall. They went from the rear LCA mount to the front Subframe. No bends in them at all. He might still have the measurments I am not sure.
Cool!! I was thinking about grabbin a long piece of 1 1/4" solid steel pipe. I thought that hollow pipe might be too weak. How much should they weigh? I was thinking that I would need to go that route b/c It would be eaiser to bend, but if your sayin that I could just get a piece of boxed steel and install it with out bending it I'll just do that. If I remember correctly the boxed sub's are stronger anyway. Right? I live in Orlando, so where should I go to pick up the steel? I don't think Home Depot or Lows would have somthing like that. Thanks for the info Ya'll
__________________
Cmbob67
Originally posted by cmbob67 Cool!! I was thinking about grabbin a long piece of 1 1/4" solid steel pipe. I thought that hollow pipe might be too weak. How much should they weigh? I was thinking that I would need to go that route b/c It would be eaiser to bend, but if your sayin that I could just get a piece of boxed steel and install it with out bending it I'll just do that. If I remember correctly the boxed sub's are stronger anyway. Right? I live in Orlando, so where should I go to pick up the steel? I don't think Home Depot or Lows would have somthing like that. Thanks for the info Ya'll
holy moly don't use SOLID STEEL...first of all it would not be as strong say as pipe being due to it's ductile and ability to move compared to true pipe, 2" square tubing x 11ga would be more than sufficient for SFC strength.
I thought about doing the same thing myself. I'm welding certified so that part would be easy. I also have a good hookup with my local welding shop to get materials very cheap and use their equipment free of charge. I bet you could get everything for$25-30 bucks and then just powdercoat them to look good. If you bought powdercoat in bulk it would work out to be pretty cheap. Probably could sell them for $70-80 bucks and make yourself some money too. Make a jig and just go down the line welding everything up. Make a little weekend production out of them and make some cash. Once word got around how good the quality was I bet people would be clawing at your door to pay half the price to get the same quality as some of the big name manufacturers. Good luck.
