MAF for 94 z28
Re: MAF for 94 z28
From startup, three conditions need to be met for transition to closed loop:
1 - O2 sensors heat up to operating temperature (~600°F), and become active.
2 - Coolant reaches required minimum temperature, usually about 140°F, but can be higher or lower.
3 - Timer in PCM times out, usually 206 seconds.
Re: MAF for 94 z28
Shoebox has the part numbers on his website. That does not appear to match any of them.
1993-1997 F-Body Part Number Collection
formula218
12-02-2014 04:27 PM
