LT4 intake manifold
Re: LT4 intake manifold
LT4 intake will not bolt onto lt1 heads...ports and angles are different i beleive.
there isn't much hp to be gained in them, it's just that they are different to accomodate the different heads.
so don't worry about it
Originally Posted by 1crazylt1
well i was goin to get the lt4 manifold from summit that fits the lt1
Requires LT4 cylinder head conversion.
After spending $200+ for the intake, and then having it machined, you can bolt it up. The gains from this will be approximately "0" HP. Although the intake runners of the LT4 heads is 0.100" taller than the ones in the LT1 heads, the LT1 and LT4 manifold runners are virtually identical. There is no difference in the openings... the LT4 intake simply has more metal at the top of the runner so they can be ported to match LT4 heads. The LT4 intake doesn't match thte LT4 heads as shipped from the factory.
All of this has been posted many times and could have been found with a "Search"
Originally Posted by Injuneer
Lets try it one more time... the LT4 intake manifold will not bolt to LT1
So are you saying it is not worth it?
Sorry.... warped sense of humor getting the best of me today
Originally Posted by 97WS6SCharged
But the red manifold looks nice.
http://cjcfo.fbody.com/members/injun.../DCP04252a.jpg
I know what you mean. http://community.webshots.com/photo/...65054499BDeYjW
What kind of fitting did you use in the fuel rail cross over pipe for the return?
Its a cut down stub of a -6AN fitting welded to the cross-over tube.
http://cjcfo.fbody.com/members/injun.../DCP04272a.jpg
07-04-2005 05:00 PM
