oil pickup
Old 01-14-2013, 08:45 AM
Chet1185's Avatar
oil pickup
What's a good way to measure and install the tube? My oil pan looks a little deformed on the bottom but no holes or anything.right now the screen is set at 7 5/8 above the block. Is there a known height above the block that works?
Thanx
Posted from Camaroz28.com App for Android
Chet1185 is offline
Old 01-14-2013, 02:29 PM
ACE1252's Avatar
Re: oil pickup
Modeling clay. I used playdoh, but I think it can expand just a little after you remove it from being compressed. Use a piece of paper to keep that stuff out of the screen(I didn't....nice little mess...). I then cut it in half and measured it.
http://www.ace1252.com/images/CC503_...easurement.JPG
I ended up with a different pickup than the stock one, but still the same principle. You just need to make sure that the pickup is secured in the pump and does not move.
I think there are some other ways of doing it, but I used the above.
ACE1252 is offline
Old 01-14-2013, 04:00 PM
Dave89IROC's Avatar
Re: oil pickup
Straight edge and a ruler, straight edge on the pickup, measure to the pan rail....straight release across the pan rails, ruler to the bottom of the pan
Dave89IROC is offline
94Form
07-17-2015 10:56 PM
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
SergheiS
07-05-2015 03:27 AM
Slayer
07-04-2015 03:06 PM
Quick Reply: oil pickup
