LT1 wont start
LT1 wont start
i have a 1994 lt1 its got spark it gets fuel through the injectors but wont start i've tryed to spray starting fluid in the intake but it still wont start it holds 40psi on the fuel pressure. need help bad the motor only has 110,000 miles wish i knew what was wrong with it
Re: LT1 wont start
Have you scanned it for codes?
Have you checked for spark at several of the plugs, AND at the coil wire?
How did you verify you have fuel through the injectors?
Did this problem pop up all of a sudden, not preceded by any changes or parts replacements?
Re: LT1 wont start
no i aint checked it for codes. how i verify fuel through the injectors was i took the whole injector system off and had my brother to turn the key while i looked at the injectors all of them was spraying fuel.
10-31-2016 11:09 AM
07-04-2005 05:00 PM
1LEThumper
07-14-2003 12:45 PM
