LT1 without a EFI or opti??? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 06-25-2008, 01:19 PM   #1
Question LT1 without a EFI or opti???
This one is a little off topic, I suppose. I have a 1964 Chevelle SS with a 283 on its last legs. I also have a 68 chevy truck my dad and I swapped a 94 LT1 and 4L60E into. The truck is about to be junked, and Iíve been wondering if it was possible to put the LT1 minus the ecm in the chevelle. I really don't want a wiring harness or ecm in the chevelle. The car has a Muncie m20 I want to keep. Iím sure Iíve seen a carb intake for the LT1 somewhere before. Iíll have to find that again. I was really curious about removing the optispark. Can I just leave it off? Will the LT1 oil pump be a problem? If I keep the LT1 water pump, the reverse flow wonít be a problem will it? Iím not set on using this motor in the car; I just would like to use it, since I already have it (the motorís tip top as well).
By the way, I would love it if someone could give me a link to a suitable intake (and any other necessary parts) for this swap. Thanks!
70cst10 is offline   Reply With Quote
Old 06-25-2008, 01:28 PM   #2
Go to summit racing and type this part # in
NAL-24502592
A regular chevy HEI distributor will work on that.
I think GMPP offers a block off plate for the opti drive that also has a timing reference on it. Not sure if they still make it. You could just weld the hole shut though.
GMRL is offline   Reply With Quote
Old 06-25-2008, 03:06 PM   #3
Use to be a common swap for Gen II into Gen I car.
U will need electric fan(s) and a fan shroud for the radiator as the LT1 wtr pmp has no way to drive a fan and fan clutch. Also a controller to operate the fan(s).
I'm just guessing but think any '87 & later model intake with the correct bolt pattern would work - but the water crossover passage and T-stat housing would have to be ignored.
I have ideas for this swap also,
cardo0
cardo0 is offline   Reply With Quote
Old 06-25-2008, 05:07 PM   #4
It is kinda pointless to use an LT1 sans the EFI. Might as well
sell the LT1 and get a carbed crate motor.
Tom
sbca96 is offline   Reply With Quote
Old 06-25-2008, 05:43 PM   #5
I might just do that. I didn't even think about the fans. My truck has the camaro rad and fan setup in it. Ah well. anybody want an lt1/4l60? haha!
Old 06-25-2008, 06:56 PM   #6
I agree on the go gen 1 if carbing it. I just wanted to post to say ther IS a way to have a mechanical fan on an LT1, the tow package b-bodies had mechanical fans, bracket that bolts over the waterpump and a second little serpentine belt and tensioner.
96capricemgr is offline   Reply With Quote
Old 06-25-2008, 07:18 PM   #7
Go to Crate Engine Depot site:
http://www.crateenginedepot.com/store/search.aspx
put LT1 in the search window and you'll see an carb intake manifold and a few new Goodwrench lt1 crate engines for sale . They are longblocks and one says it's the P Camaro or Corvette motor for 92-94 so it should have the aluminum heads.
The intake manifold looks pretty nice.
97WS6 is offline   Reply With Quote
Old 06-25-2008, 10:57 PM   #8
ACE1252's Avatar
According to "How to Rebuild LT-1/LT-4 Small-Block Chevy Engines"; the part numbers for the 4-barrel intake manifolds are.....
LT1 - 24502592
LT4 - 24502574
For the cover in place of the Opti-spark....
GM cover plug - 12367600
Throw the numbers into www.gmpartsdirect.com and you can see pictures of them.
"How to Rebuild LT-1/LT-4 Small-Block Chevy Engines" also says.....
"Because the original torsional damper is 7 1/2" in diameter, it won't clear the timing tab on the front cover plug plate. If using a rear mount distributor, you'll need to install a 0.184" x 0.680" key into the crank snout's front key slot and obtain a small-block Chevy zero-balanced damper with a diameter of 6 3/4"(commonly available). This will completely replace the OE hub adapter and damper."
The book documents how to rebuild the LT1/4 to stock fuel injection, but they also documented how to convert it to a carbed application. Excellent book.
This may be useful too....
http://www.edelbrock.com/automotive_...2000/24206.pdf
ACE1252 is offline   Reply With Quote
Old 06-26-2008, 08:16 AM   #9
new camaro mag, has a build up of lt1. Block off plate on it, using a electric water pump, GM intake for carb and dist. at rear. Great article. Thinking of using spare lt1 as my play motor in a g body. No Pwr steering a/c etc etc , straight motor electric WP and electric motor for alt. Let her fly with carb and dist. see what happens
wyldcdn is offline   Reply With Quote
Old 06-27-2008, 02:28 PM   #10
Where to get a mechinical fan bracket?
Quote:
Thx for posting Dwayne as i did not know this. I would prefer the mechanical fan for a GEN II conversion.
Looks like the Buick Roadmaster station wagons and the Impallas with the GEN II blocks had this bracket. Can i still buy the mechanical fan bracket from the GM parts houses?
cardo0
Reply
Thread Thread Starter Forum Replies Last Post
HP Tuners for Boost.... DirtyDaveW Forced Induction 13 12-01-2016 06:37 PM
Lt1 parts- msd opti, crane springs, ect nikolt1 Parts For Sale 2 02-27-2015 10:10 PM
LT1 24x Conversion Parts Queens94z28 Parts For Sale 3 12-20-2014 10:11 PM
Watch Cheap Opti Fail on the Test Bench Injuneer LT1 Based Engine Tech 5 12-15-2014 10:36 AM
LT1 stuff for sale Hot Rod Hawk Midwest 4 08-30-2002 11:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
