lt1 vs...
Old 08-01-2011, 11:06 AM
Beez28's Avatar
lt1 vs...
well im a newb, but im curious what you guys think, should i keep my lt1 engine and just build that up, or should I drop a 396 or any other engine in my 1994 z28 body? what would you guys do? its an auto, and has 126k miles
Beez28 is offline
Old 08-01-2011, 11:53 AM
calaban's Avatar
Re: lt1 vs...
The only engines that are an "easy" swap are LSx engines since the ignition system does not require a standard type distributor. There is very little room under the cowl for a standard distributor setup.
calaban is offline
Old 08-01-2011, 12:21 PM
Mystery Bird's Avatar
Re: lt1 vs...
Do you mean a 396 LT1 stroker or and old school BBC 396?
Mystery Bird is offline
Old 08-01-2011, 09:30 PM
calaban's Avatar
Re: lt1 vs...
I assumed by his wording he meant an old school engine, but a stroker would fit.
calaban is offline
Old 08-02-2011, 08:50 PM
30th97z's Avatar
Re: lt1 vs...
"KEEP THE LT1 & BUILD IT"!!!!
30th97z is offline
Old 08-02-2011, 09:26 PM
calaban's Avatar
Re: lt1 vs...
That's what I say as well.
If you are going to swap the engine, go to an LSx. By the time you are done you might as well buy a LSx car. Probably cost about the same in time and money to swap it in.
calaban is offline
Old 08-02-2011, 09:39 PM
WS Sick's Avatar
Re: lt1 vs...
Unless you find a wrecked LS1 car for the swap I would stick with an LT1 and have fun.
WS Sick is offline
oldschool
02-09-2016 09:21 PM
DirtyDaveW
03-15-2015 07:01 PM
Noer
02-28-2015 11:29 AM
InfernalVortex
01-17-2015 09:35 AM
Hot Rod Hawk
08-30-2002 10:12 PM
Quick Reply: lt1 vs...
