lt1 vs...
lt1 vs...
well im a newb, but im curious what you guys think, should i keep my lt1 engine and just build that up, or should I drop a 396 or any other engine in my 1994 z28 body? what would you guys do? its an auto, and has 126k miles
Re: lt1 vs...
The only engines that are an "easy" swap are LSx engines since the ignition system does not require a standard type distributor. There is very little room under the cowl for a standard distributor setup.
oldschool
02-09-2016 09:21 PM
