LT1 Tech questions
LT1 Tech questions
Hey guys great site you got running here. Was wondering If I could get some answers to a few questions about my LT1. Does anyone know the max lift a stock valve spring will take? Has anyone ever used the edelbrock LT1 performer cam. part #2108? What kind of gains will I get from a 1.5 roller rocker setup? How much HP is gained from a dual exhaust setup, headers and flowmasters? and finally does anyone have suggestions to squeeze extra hp out the engine with spending a bunch.
Thanks A lot guys
Thanks A lot guys
Re: LT1 Tech questions
Welcome to the Site.... The stock spring are good to around .490, I believe... The Edelbrock cam is basically like a LT4 Hot Cam... Do you mean 1.6 ???? Exhaust varies between 8-30 HP, depending on set up....
Use the search function.... Most of you questions have been asked in the past....
oldschool
02-09-2016 09:21 PM
ChrisFrez
11-23-2014 10:33 AM
Caps94ZODG
10
09-09-2002 12:08 AM
