Re-using head bolts
Old 04-18-2007, 07:03 PM
Spitfire557's Avatar
Re-using head bolts
Sorry if this has been covered before, but is it safe to re-use head bolts? I bought brand new ARP bolts when I did my LE2 heads, now maybe 25 miles later (sucks!) I am ripping the heads off again. Can I safely reuse the ARP's, or am I stuck buying new ones? Thanks!!
Spitfire557 is offline
Old 04-18-2007, 07:09 PM
VK
VK's Avatar
ARP bolts can be reused unlimited number of times.
VK is offline
Old 04-18-2007, 07:21 PM
Awesome, that's all I needed to know. Thanks!!
Old 04-18-2007, 10:42 PM
...or until they break...
shoebox is offline
Old 04-18-2007, 11:15 PM
Moderator
Javier97Z28's Avatar
Just make sure to clean 'em up after removal. A wire wheel on a drill worked nicely for me.
Javier97Z28 is offline
Old 04-19-2007, 02:42 AM
gitsum's Avatar
Dont mean to hijack, but can you reuse stock head bolts?
gitsum is offline
Old 04-19-2007, 02:53 AM
Black_Z's Avatar
Buy a set of ARP's. If you re-use the stockers you will be buying new gaskets and bolts sooner than you would like.
Black_Z is offline
Old 04-19-2007, 07:07 AM
It is not advised.
shoebox is offline
Old 04-19-2007, 09:28 AM
VK
VK's Avatar
Originally Posted by shoebox
It is not advised.
I second that. But i have done it on other POS cars
VK is offline
10-31-2016 11:09 AM
maybe2fast
03-16-2015 09:45 AM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Re-using head bolts
