Lt1 heads VS vortec heads
Old 05-16-2006, 02:31 PM
MAJESTIC's Avatar
In a comparison to both heads do the vortec outflow our Lt1
heads?? Or are both heads heads equal in flow???
I have been reading the vortec's are awesome for perfromace use.
MAJESTIC is offline
Old 05-16-2006, 02:53 PM
Moderator
Javier97Z28's Avatar
Re: Lt1 heads VS vortec heads
I believe they flow similar #'s in stock form, but are iron castings.
There's no benefit over what we currently have.
Javier97Z28 is offline
Old 05-16-2006, 04:09 PM
Steve0's Avatar
Vortecs arent so much "awesome" as much as they are just a good value. The vortec head gives good performance potential at a very competitive price. Vortec's were modeled after lessons learned during the development of the LT1 head.
This article has a little bit of history behidn the vortec head in it:
http://www.chevyhiperformance.com/te...8_0507_vortec/
In stock form the LT1 head is superior... not only is the LT1 lighter being aluminum, but the stock Vortec head can only take .420 lift in stock form. You can get aluminum vortecs, as can you get modded vortecs that take more lift, but then of course your price goes up. Once you start modding them, I am willing to bet that both heads will max out around the same range.
It doesnt really matter too much for our cars though... you cant put a Votec head on your LT1, and can't put a LT1 head on a Gen I smallblock.
Steve0 is offline
Old 05-16-2006, 04:39 PM
LameRandomName's Avatar
They are. For people with old style heads.
It's a little difficult for you younger folks to get a real feel for how far heads have come in the last 20 years. As late as the mid-late 80's, a set of 2.02/1.60 Angle Plug heads were still a big deal and undercut valve stems were practically black magic.
LameRandomName is offline
Old 05-16-2006, 04:50 PM
WS Sick's Avatar
I remember digging though swap meets loooking for a set of "041s" and "186s". Does that show my age...lol ?
WS Sick is offline
Old 05-16-2006, 08:17 PM
thesoundandthefury's Avatar
You might wanna do some research on Fast Burn heads. They were based off of the Vortec design. One of the main reasons, (aside from them not being reverse cooled), that a Vortec head will not fit an LT1 is that the bolt holes for the intake mating flange are drilled at both a different angle and higher up in the mating surface. The Fast Burns however are drilled for both the Vortech and standard SBC intake pattern. If a guy were ambitious enough, he could convert some Fast Burn heads to reverse cooling, and then maybe run either a Vortec or raised runner Bowtie single plane intake. (LT4 would work too if you did a conversion.)
Here's a flowchart comparison between Fast Burn's and LT1's:
GM LT1
Valve Size: 1.94/1.50
Chamber Size: 58cc
Intake Runner: 170cc
Exhaust Runner: *
Flow Int./Exh.:
.100 72/53
.200 129/101
.300 180/136
.400 213/155
.500 214/165
.600 215/171
GM "Fast Burn"
Valve Size: 2.00/1.56
Chamber Size: 62cc
Intake Runner: 210cc
Exhaust Runner: 78cc
Flow Int./Exh.:
.100 62/55
.200 136/104
.300 187/133
.400 232/158
.500 266/180
.600 275/193
http://www.purplesagetradingpost.com...%20Fast%20Burn
thesoundandthefury is offline
Old 05-16-2006, 10:30 PM
chrism400's Avatar
GM "Fast Burn"
Chamber Size: 62cc
Flow Int./Exh.:
.100 62/55
.200 136/104
.300 187/133
.400 232/158
.500 266/180
.600 275/193
[/I
The Fastburns are a good head but you can buy better for less money. BTW those numbers you got are not real Fastburn numbers. Those are from a prototype head. They don't flow nearly that much in stock form. You can go here and look up the Fastburns tested by Salee Chevrolet. There is a comparison of the old FB's to the new ones. It's at the bottom of the page.
http://www.sallee-chevrolet.com/frame.html
chrism400 is offline
Old 05-16-2006, 11:07 PM
Like what?
Old 05-17-2006, 08:48 AM
chrism400's Avatar
What are you building? The Vortecs with a little exhaust work may be suitable for your application. They remind me of the old Dart II's. Decent intake numbers but the exhaust flow needs some attention.
Old 05-17-2006, 08:50 AM
WS Sick's Avatar
Some Brodix Race rites, and T1s, Pro Actions,even the Edelbrock Victors are comparable.
WS Sick is offline
InfernalVortex
01-17-2015 09:35 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
thenewkid
11-27-2014 09:41 AM
Wilson
07-21-2002 05:08 PM
Wilson
07-21-2002 04:58 PM
Quick Reply: Lt1 heads VS vortec heads
