Cloyes Double Roller
Old 02-04-2020, 11:33 PM
DrewHMS97SS's Avatar
In a double roller setup, does anything need to happen with the hub? I know an EWP is needed, but what other mods need to be made?
I am looking to convert to the Torquehead setup, and the lack of reluctor being needed got me thinking about the hub and the difference in thickness of the gear and how that would push out the hub.
DrewHMS97SS is offline
Old 02-07-2020, 07:03 PM
Re: Cloyes Double Roller
I hear that the actual thickness of the double gear is the same as the single, is this accurate?
Old 02-11-2020, 01:33 PM
bw_hunter's Avatar
It is. The thickness at the outer diameter where the teeth are is thicker and I had to clearance the timing cover on my '94...
bw_hunter is offline
Old 02-13-2020, 10:46 PM
Thanks! I had not looked close enough, but the inside of the gear is concave.
97superchgedz28
10-01-2013 04:35 PM
G. McDonald
04-03-2007 07:45 AM
LenT1
01-31-2007 04:57 AM
LT4orbust
09-16-2005 01:01 PM
kirschman
03-18-2003 05:16 PM
Quick Reply: Cloyes Double Roller
