LT1 cooling problems..
Old 11-10-2014, 10:11 AM
  #16
DanDalessandro's Avatar
Re: LT1 cooling problems..
Hey guys, so I finally had time to do the radiator yesterday, and I got it all together, and I started pouring coolant in, until it started leaking out of the water pump. It came out on the passenger side. I checked the bolts, and they were loose, so I tightened, and no leaks. Finally pulled it outside, started it, and the passenger side was still leaking. I missed a bolt so, it's all good now. Ran fine, gauge wasn't all over the place (Knock on wood). The loose water pump can explain where i was getting air in the system, so hopefully I'm all sorted out.
I just have a question. Should the radiator be topped off, when the engine is cold?
Thanks again for all of your help!
DanDalessandro is offline
Old 11-10-2014, 12:10 PM
  #17
Shoebox has a refill procedure:
4th Gen LT1 F-body Tech Articles
Injuneer is offline
10-31-2016 11:09 AM
HectorM52
06-23-2016 08:42 PM
MattFick
02-15-2015 10:16 PM
FIREBIRDMARK1
01-07-2015 03:36 PM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
Quick Reply: LT1 cooling problems..
