LT1 carbed intake ? and need pics.
Old 02-15-2009, 04:17 PM
383racecar's Avatar
well im looking into going carbed with my lt1,(sick of only being able to turn 7200rpm and optis) right now the car sits with le2 heads intake,bre custom cam, my main ? is who makes a carbed singal plane intake that will bolt up to the lt1 heads?
383racecar is offline
Old 02-15-2009, 04:27 PM
LaredoZ28's Avatar
I believe Edelbrock makes an intake that bolts up to the LT heads. They have what they call a victor jr. that bolts up to LS heads so they should make one for LT's.
http://www.edelbrock.com/automotive_...vy/chevy.shtml
LaredoZ28 is offline
Old 02-16-2009, 04:57 PM
1quikZ's Avatar
GMPP makes one, im running it on my carbed t1 s10
1quikZ is offline
Old 02-16-2009, 06:01 PM
Venomous360's Avatar
That is Correct that is what I had on my 86 IROC with LT1 heads. Worked like a charm. Other than the Remote Thermostat housing is a pain, but a WTF at car shows.
Venomous360 is offline
Old 08-11-2009, 11:42 AM
cleangene's Avatar
yes there is a carb intake for LT!
https://store.gmperformanceparts.com...-24502592--%3E
has anyone tried it, would love to get rid of the opti
cleangene is offline
Old 08-11-2009, 11:55 AM
ulakovic22's Avatar
GMPP is the only one I know of. You can use a std. SBC intake manifold, but you have to convert the bolt pattern to match the LT1 heads. If you want you can cut out the thermostat neck as well since the LTx is a dry manifold.
ulakovic22 is offline
Old 11-19-2010, 05:28 AM
SCNGENNFTHGEN's Avatar
Re: LT1 carbed intake ? and need pics.
I have the GMPP one.Nice piece. The real question is? How much will I have to massage the firewall with a BFH to fit in a traditional HEI ditributor as well.
SCNGENNFTHGEN is offline
Old 11-19-2010, 08:11 AM
cnorton's Avatar
I have seen it done with an MSD distributor but not an HEI. I don't know about the firewall clearance for an HEI but the vertical clearance for a tradtional distributor in a 4th generation F-body needs some consideration. The distributor needs to be in the motor when it goes into the car and there won't be much of a chance for pulling it back out once the motor is settled into place.
cnorton is offline
Old 11-20-2010, 02:31 PM
My replacement LT1, just happened to come with the intake, & a new MSD street fire distributor. As well as some brand new motor mounts for the the 350 I'm putting into my 67 C20. I'm just going to hold onto the intake & dist. for another project. I'll be swapping my LT1 intake & opti, once I get it out.
Old 11-21-2010, 05:20 PM
wyldcdn's Avatar
fastfatboy runs one. He out of Mobile AL
wyldcdn is offline
Old 11-21-2010, 11:15 PM
Mr.GearheadZ28's Avatar
I have a carbureted LT1 in my Camaro. I'm using the GMPP carburetor manifold with a 750 Holley 4150 HP carburetor. For a distributor, I would advise using Mallory's Max-Fire electronic distributor with the large style cap (shorter but wider than the smaller one). You can fully tune it with a laptop computer (good luck fiddling with weights and springs as you can barely remove the distributor cap). I can tell you EVERYTHING you'll have to do if you want. You can view my F-quick link in my sig for reference and further mods. Also, you will need to cut part of the cowl to fit the carburetor. I can post pictures of the engine in the car and how I cut my cowl and any measurements you may need. I cut it with the engine in place; so it fits like a glove. A cowl induction hood may be in order: as your air filter selection will be limited. Any further questions please PM me.
Last edited by Mr.GearheadZ28; 11-21-2010 at 11:21 PM. Reason: needed to provide more information
Mr.GearheadZ28 is offline
Old 11-22-2010, 02:08 PM
<Puck>'s Avatar
FFB runs an EFI converted supervic with a 4bbl TB, but is not carbed.
<Puck> is offline
oldschool
02-09-2016 09:21 PM
InfernalVortex
01-17-2015 09:35 AM
markaubuchon
3rd Gen / L98 Engine Tech
01-14-2015 01:48 AM
Quick Reply: LT1 carbed intake ? and need pics.
