A/C Compressor
Old 06-21-2011, 11:06 PM
FAST96Z's Avatar
A/C Compressor
Have a ? my compressor is making a loud grinding noise so im sure the compressor is no good.Car has been in the garage for 2 yrs now just moved it out the garage yesterday.Im thinking should i go with the delete pulley or new compressor or ebay has CAMARO AC Compressor Clutch Bearing.will that solve the problem.IT NEEDED A NEW 6 SPEED ,FLYWHEEL ,CLUTCH ...ETC
Eric
FAST96Z is offline
Old 06-22-2011, 08:25 AM
95TA04GOAT's Avatar
Re: A/C Compressor
That's all up to you. If you want to be able to drive it cheaply and don't really care about having a/c, throw a delete pulley in there. Does the noise only happen when the clutch is freewheeling or is it when the clutch is engaged and actually turning the ac compressor. If it's only when it's free wheeling then it does sound like the clutch bearing is bad. If you have access to the too to pull the compressor clutch off then go for it. If not, you may be better off just throwing a new compressor in there.
95TA04GOAT is offline
2QUIK6
09-17-2016 02:31 PM
magman
04-15-2016 03:08 AM
War Engine
09-18-2015 07:28 PM
WPHIG2
08-27-2015 06:37 AM
AtlasXVIII
08-24-2015 11:41 PM
Quick Reply: A/C Compressor
