LS7 Card MAF
LS7 Card MAF
Is this a possible swap? the PCM only supports 11200hz max. We would have to scale the MAF tables but from what I have read it is a great MAF and is very accurate...might help drivability.
Also I have a lid conversion so I could run a 90mm calibration for the MAF
Re: LS7 Card MAF
It should work just fine. I am doing something similar by adding a card maf to a 4" inlet. You just need to scale it for whatever dia. it is going into and then maybe adjust it a little for a decent fuel trim.
09-18-2015 03:46 PM
