Looking for help here
Re: Looking for help here
it certainly is not a "direct" swap. Two completely different engine platforms, wiring and ECU's
With enough time, effort & $ anything is possible
You would be better off finding a 94-96 roller and swap over your drive train
^ word .. but don't let the auto thing fool you. The car will have been designed for a manual as well. There will be knockouts for the clutch hydraulics. ditching the LT1 or finding a 94-97 roller would be best. Not much to make a OBD1 motor run on an OBD2 harness if you found a 96-97.
f-bodyv8
3rd Gen / L98 Engine Tech
06-23-2002 06:40 PM
