Looking To Get CamShaft, also do I need to program?
Hey guys;
I'm looking to get a camshaft for my 93. I still have no idea what to get and don't know much about cams. I have stock heads, bottom end, etc. I basically just have bolt ons, (cat back, cold air, 1.6 rockers, etc) I'm not sure where to get a cam or what to look for. I only drive it on weekends, and want something pretty mild, not loppy, and somewhat smooth idle.
In getting a cam, do you also need to program your ECM? I have a hypertech chip from way back in the day, and havn't done anything beyond that.
Where do I go from here? Thanks in advance
Re: Looking To Get CamShaft, also do I need to program?
Hey guys;
For the cam, there are several smaller grinds that will suit your needs. AI and LE both sell terrific semi-custom grinds listed on their webpage. Since your requirements are fairly docile, you could also roll with the CC305. (Un)fortunately there's TONS of info available, but I'd start with AI/LE.
You will certainly need to have the ECM reprogrammed.
www.elliottsportworks.com
They are two vendors that are well-versed in LT1-specific performance. They do not reprogram ECMs, but there are several aftermarket companies that do. Do a search for PCMforless, Ed Wright, Fastchips, Madz28, etc.
A cam install is certainly not a "budget" endeavor. Plan on allocating right around $1000 minimum to be done properly.
You have to consider lifters, rockers, pushrods, maybe guideplates. One thing usually leads to another. The whole thing is a lot more than "just a cam".
You should consider full bolt-on's first, headers, gear, real tune and a stall aren't mentioned and are recommended prior to the cam change also.
well I already have rockers and springs. 1.6 actually. I have headers, Y pipe etc. I don't really want a gear. So really I'm technically ready for a cam I think personally. Just wasn't sure about tuning, etc or why its needed. I'm assuming so I don't stall or use god awful amounts of fuel, etc...
I found this that works with aftermarket chip & upgraded exhaust which is what I have
http://www.compperformancegroupstore..._Code=LTCAMSXE
