Kickdown/shift cable hook up
Old 06-17-2012, 04:18 PM
tapoutjay44's Avatar
Guys, I dont own a camaro, but my engine is out of a 97 Z28, and i recently rebuilt it and dropped it into my 1982 chevy full size blazer 2wheel drive. The problem I came across is hooking up the shift cable from my 700r4 to the throttle blades on the throttle body. The throttle linkage on the old carb turned clockwise when you punch it and would shift the trans...now on the throttle body it turns counterclockwise when you accelerate. Is there any way to hook up the cable???? thanks
tapoutjay44 is offline
Old 06-17-2012, 04:58 PM
Kevin Blown 95 TA's Avatar
Re: Kickdown/shift cable hook up
can you fab a bracket to go to the top instead of the bottom or something like that?
Kevin Blown 95 TA is offline
Old 06-17-2012, 05:09 PM
Dave89IROC's Avatar
You need a throttle body, cable and bracket for a 93 camaro, or you need to fab something up
Dave89IROC is offline
Old 06-18-2012, 02:54 AM
thanks guys. At least now I have an idea of what to look for at the junkyard, and where to start. I could probably fab it up if I knew what it looked like.
G-BODYT56
01-14-2022 11:14 PM
Novo
06-14-2016 02:58 AM
93 RedBird
11-15-2015 08:24 AM
jackpawt883
09-10-2015 08:53 PM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
Quick Reply: Kickdown/shift cable hook up
