I have my water pump off! Can I get rid of my airpump now??
Old 12-28-2004, 12:48 PM
cmbob67's Avatar
I've pulled the water pump off and now getting ready to put it all back together. I was wondering if I could leave the air pump and bracket off? It looks like everything else can be put back together without reinstalling the air pump and the "pain in the @*%" bracket.
cmbob67 is offline
Old 12-28-2004, 01:01 PM
tanker's Avatar
Re: I have my water pump off! Can I get rid of my airpump now??
Yep, but if you decide to move to California, it will have to come back. Make sure you keep it
tanker is offline
Old 12-28-2004, 01:08 PM
cmbob67's Avatar
Thats cool. Is there some instructions posted somewhere? I wanna make sure I do it the right way. Can I leave the bracket on that side off and just attach the coil to the head?
cmbob67 is offline
Old 12-28-2004, 01:58 PM
SnakeSkinner28's Avatar
If you are still running cats on your car then you cant remove the AIR pump. Over time not having it on there will clog up the cat with unconverted exhaust.
SnakeSkinner28 is offline
Old 12-28-2004, 02:09 PM
cmbob67's Avatar
What if I plan on removing the cat withen the next month or 2??
cmbob67 is offline
Old 12-28-2004, 02:11 PM
Black_95Formula's Avatar
They will die a lot sooner then that, but I don't see a major problem other then the "rotten egg" smell that will come out of your exhaust...
Black_95Formula is offline
Old 12-28-2004, 02:23 PM
It shouldnt die that quickly. My air pump was bad for probably close to a year before i had any problems that were noticeable. If you want to be safe then hold off, having the water pump off doesnt necessarly make it easier to remove the air pump. However, i wouldnt worry about the cat cloggin in a month, you will notice when it does because you will have no power and your manifolds will be glowing red.
Old 12-28-2004, 02:30 PM
Oh yeah, I have heads/cam, that's why mine rotted only after a week!
Old 12-28-2004, 05:37 PM
NOMAD's Avatar
Pull it off and plug anything up that needs it. You will be fine
-Shannon
NOMAD is offline
HectorM52
07-30-2017 11:46 AM
Biggiebound
04-21-2015 11:28 PM
KYWes
04-15-2015 07:28 PM
Blood type Z28
04-08-2015 11:34 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: I have my water pump off! Can I get rid of my airpump now??
