How much labor in a valve cover gasket change?
Old 03-02-2003, 09:31 PM
Burn_Out's Avatar
I have a bad oil leak on my driver side valve cover and was wondering how hard of a job that is to change the gasket out, thanks.
Burn_Out is offline
Old 03-02-2003, 09:37 PM
94 CAMRO Z28's Avatar
Valve covers are easy, especially the drivers side. Probably about 10-15min. job your first time around, once you done it before you could pull it, install the new gasket, and bolt it back down probably within 5min. The gaskets on the valve covers and just a rubber/foam that pops into a recess within the cover, so its not hard at all. As simple as unscrewing four bolts. Hope this helps.
Aaron
94 CAMRO Z28 is offline
Old 03-02-2003, 10:51 PM
Not sure if I had to, but it seems like I remember removing the AIR diverter from the exhaust manifold to get the cover off. It can be troublesome if it is stuck. Definite anti-seize used when putting it back on.
shoebox is offline
Old 03-02-2003, 11:00 PM
1loudz's Avatar
Someone having a 428 r.w.h.p. car and not being able to change the valve cover gasket, is just not right!
1loudz is offline
Old 03-02-2003, 11:01 PM
Hey how much are you looking to get for your car?
Aaron
Old 03-03-2003, 12:58 AM
GeneralZ's Avatar
It took me longer to find the right socket than it did to change my both my gaskets.
GeneralZ is offline
Old 03-03-2003, 01:40 AM
SVT Killer LV's Avatar
easy s#it man.. do it yourself... you have over 400 rwhp and you need somebody to do that? something doesn't add
SVT Killer LV is offline
Old 03-03-2003, 02:23 AM
blown383's Avatar
I'd charge you a slice of pizza and a can of coke.
-B
blown383 is offline
HectorM52
01-30-2015 11:34 PM
Jazsun
12-29-2014 12:14 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Snoman73
11-17-2014 07:22 PM
Quick Reply: How much labor in a valve cover gasket change?
