How much labor in a valve cover gasket change?
Valve covers are easy, especially the drivers side. Probably about 10-15min. job your first time around, once you done it before you could pull it, install the new gasket, and bolt it back down probably within 5min. The gaskets on the valve covers and just a rubber/foam that pops into a recess within the cover, so its not hard at all. As simple as unscrewing four bolts. Hope this helps.
Aaron
Aaron
Not sure if I had to, but it seems like I remember removing the AIR diverter from the exhaust manifold to get the cover off. It can be troublesome if it is stuck. Definite anti-seize used when putting it back on.
