How do i use dielectric grease, and should i?
I threw in ngk-tr55 plugs today and want to put in my taylor wires tomorrow that came with some dielectric grease. I was wondering what am i supposed to do with it? I hear you put it in the boot but where do you put it? Do you put it where the plug and wire contact each other? or just a little on the rubber part? I am wondering if i should use it at all?
Re: How do i use dielectric grease, and should i?
Take a Q Tip and put a small amount in the plug end boot and metal connector,do the same on opti end.Your boots will come off the next time you change the plugs without having to pry them off.
Originally Posted by White Knight
I never use that stuff. I see no point at least with how and where i drive my car.
FWIW i put about a peanut-sized amount in the end of each boot. That way when you slip it on it seals the boot and connections... even at the opti. Been running like a champ for the last 40,000+ miles and the boots pop off without a hassle.
ya i always do about a peanut size or even a lil more in each end of the wire and just stick it on. Works fine everytie ive done it. Probably 10-15 times now with all teh cars ive owned.
30th Anniv Z28
08-01-2015 10:39 AM
GetaZforgetGT
05-10-2003 07:09 PM
scoobysnax83
04-02-2003 10:43 PM
Ray66
11-07-2002 09:01 PM
