Car does not idle well and backfires when getting of gas
Old 03-03-2007, 07:54 PM
rasputin's Avatar
So the car ran great for about 1500 miles, and now for the last 300 miles, it has not been idling well. From what I can tell, the idle is set at 800rpm, and goes down from 790rpm to 840rpm as it lopes when its working correctly. Now it does one of two things; idles in the low 700's then tries to pick its self up back to 800 and does so after about 10-15 seconds, or idles at 400-500 and tries to bring its self up and sits around 600, then after about 10 seconds brings itself up to 700. WTF
The unusual thing is I can tell when its gonna do this. It doesn't always idle wrong which is the thing that gets me, although its been getting worse everyday that goes by. Ideally I start the car it either does its usual 1000rpm warm up to 900 rpm, and then 800rpm. I can tell when its not gonna idle right because it doesn't do the 1000rpm jump and just kinda sits around 700. I hope that makes sense, I will try and get a video of it.
When its not idling right, when I get off the gas in gear and let it engine break, it backfires below 2500rpm.
Interesting Facts:
*Doesnt always idle bad, maybe one in three times of starting the car.
*When idling bad, the car backfires
*Car was fine for 1500 miles, now does this
*Got much worse when the new racetronix kit was installed
*New opti - car is smooth all the way up to 6200rpm
*New plugs, wires - feels fine once the car is driving, but not idling
rasputin is offline
Old 03-03-2007, 10:15 PM
OBE1 95Z28's Avatar
Check for vacuum leaks. Might also want to clean your IAC and the associated passages in the TB.
OBE1 95Z28 is offline
bfmv13trivium
01-14-2015 09:57 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
blac94Z
11-24-2014 07:12 PM
USAirman93
11-24-2014 03:37 PM
F(ast)-body
02-26-2003 09:05 AM
Quick Reply: Car does not idle well and backfires when getting of gas
