Hole in radiator - running hotter?
i had a hole in the plastic part of my radiator, i patched it but its not totally airproof. Could this make my car run hotter by letting air into the system? note. im not losing coolant, radiator is full.
thanks
thanks
Coolant will boil sooner at a lower pressure. The system should be sealed and capable of the proper pressure so it can work efficiently.
With a hole in the system, it will try to draw in air when it cools down.
were u leaking radiator fluid when u had the hole. was it a good size.
i am just curious because i have a somewhat of a similar problem. i also saw the same problem on a friends 99z28.
is it by the battery down a little bit?
anyways give a reply or a pm. i live in west seneca. do u hang out w/ the ubrf people.
edit- also forgot to ask, what did u use to patch it.
10-31-2016 11:09 AM
edman
01-22-2015 02:45 PM
