high rpm
high rpm
ok ive come to the conlusion that i want to raise my rev limiter. when my car is running right it wants to keep pulling in each gear. but my rev limiter kicks in and it wont let me. so i want to raise it a little higher. whats the safest level i can raise it too with the stock valvetrain? and what do i have to do to raise it to the 7k level. i know i will have to have a custom cam built and also have bigger lighter pushrods and stronger valve springs but where do i find them and whats the wallet damage gonna be?
Re: high rpm
if your car is stock there is no need to have the rev limiter removed because the our motors don't pull that high. I have my rev limiter set at 6700 and i have heads and a big cam. You don't need to remove it until you have at least a cam.
Re: high rpm
not to hijack a thread...but how much will the bottom end take for revving? I have head/cam but the bottom end is 143k mile stock..I usually shift at 6k or so...racing of course.
Re: high rpm
Re: high rpm
http://www.cardomain.com/memberpage/533678/7
check out my dyno. my car doesn't seem to loose any hp after it peaks out. and i have better oil and pulleys done to it, this week i should have my headers and high flow cat on thier. so it will pull alot better on the top
