High IAC and Low idle only in Drive/Reverse
Old 09-06-2005, 08:49 PM
C Man's Avatar
Not sure what the heck is happening.
In Park, the car Idles fine... good enough for a lumpy Cam anyways.
The IAC's are normal.
I put the car in drive or reverse... and the IAC's max out at 160 (on Scanmaster) and the car searches for idle... and drops really low and surges... if I wait too long, the car will die.
No driveability issues... car runs strong with no sputtering, etc. at any other speed... even IAC's drop once the car gets going.... only problem is idle.
I've searched the board with no answers.... so I thought I'd post to see if anyone knows what the heck is happening.
BTW, the car has the LTCC ignition and a Edelbrock 58mm TB... not sure if it makes any difference.
Thanks in advance for your help guys.
C Man is offline
Old 09-07-2005, 07:03 AM
C Man's Avatar
Re: High IAC and Low idle only in Drive/Reverse
Just thinking of solutions.... does anyone know if our tranny has any sort of vacuum actuator of some sort that only works when the car is in gear?
C Man is offline
Old 09-10-2005, 09:11 PM
C Man's Avatar
I'm thinking that I'm not loosing vacuum... but adding a load on the car when in Drive/Reverse.
I have opened up the TB Blade a litte by adjusting the screw..... IAC's remain pretty high in Drive but the car doesn't stall. However, the idle in Drive with the foot on the brake, still surges/drops, etc. It actually drops pretty low... than "Catches" itself... for a little bit.. than surges.
When putting it back in Park ... the car revs a little while the IAC adjusts... then idles perfectly fine.
Anyone else have this problem? Could it be the 58mm TB. Is it the LTCC ignition system? The car runs great other than this problem.
C Man is offline
Old 09-10-2005, 10:52 PM
I would say it is the load when it is put in gear. How was the tune altered for your mods?
shoebox is offline
Old 09-11-2005, 06:45 AM
Dave89IROC's Avatar
i seem to remember some people needing to drill the bleed hole larger in that throttle body, the problem was that the IAC couldn't compensate enough, the IAC steps at 160 means it is trying to get more air in there but couldn't
Dave89IROC is offline
Old 09-11-2005, 09:34 PM
C Man's Avatar
I'm not sure "how" it was tuned... but I did get it Dynotuned after the 383.. but not after the 58mm TB install.
I did get a hole drilled... but even opening the TB Blades more doesn't help too much more... so would a bigger hole make a difference?
Do you think the abrnormally high IAC values may indicate a Vacuum leak? Maybe the car is running lean because of Vacuum... fuel added in to compensate, and then needs more air.. etc.
C Man is offline
Old 09-11-2005, 11:15 PM
If you had a vacuum leak the counts would be lower, because it would not need as much air.
shoebox is offline
Old 09-17-2005, 03:10 PM
C Man's Avatar
What do you think it could be then... it only happens in Drive/Reverse... with the foot on the brake.... if I just let the foot off the brake, the car will move forward... and there aren't any problems.
Foot on the brake in Park/Neutral has no issue.
C Man is offline
Old 09-17-2005, 03:17 PM
Dave89IROC's Avatar
try this, create a vacuum leak, pull off one of the small vac lines on the intake(not the one to the fpr), see what happens to the iac counts and how it runs
Old 09-21-2005, 10:15 PM
C Man's Avatar
I think I have found the problem.
When I removed the Brake Vacuum hose and plugged it, the problem went away.
It seems that when the engine is under load and the brakes have to "work" to stop the car from moving, at low Idle, the brakes are sucking the vacuum and causing a problem.
I may have to invest in a Vacuum Reserve Canister... but before that, are there any "tricks" to minimize the issues associated with this problem? ie. would lowering or raising the idle in Drive, or changing the timing, etc. improve the brakes and vacuum enough to avoid getting a Vacuum Reserve Canister?
C Man is offline
lt1matt
03-21-2015 07:35 PM
grgguy
17
02-23-2015 07:57 PM
camy 1993
02-03-2015 06:26 PM
01-23-2015 01:13 PM
snksknr94
08-02-2002 07:31 PM
Quick Reply: High IAC and Low idle only in Drive/Reverse
