help! my cooling fans dont turn on
My car was recently in an accident... well I got all the cosmetics done, but now my fans wont turn on. I know that the fans themself work because I can hook them up direct to where they are running all the time but thats only a temparary fix(and doing that I have to pop the hood everytime I turn the car off to unplug the wires and vice versa).. I bought 2 new relays(for the primary and secondary fan relay) for the fuse box under the hood and still the fans dont trigger themselves on when the car starts to warm up. What do you all think the problem may be?
Do you have an SES light? If you do, it may indicate a problem with the circuit. Try popping the plastic cover off the relay and manually triggering it to see if the fans come on. You can move that relay between the high power and low power fan relay sockets to test both of them.
Try the relay test anyway
You're not testing the relays, just that u can use the relay to manually trigger the fans. It's quick and easy and a helpful diagnostic.
Originally posted by irocdreamer
In the meantime take out your AIR pump fuse. Your SES light will come on but your fans will run all the time. That'll save you from popping the hood all the time.
Another way to test the fans on your 1994, is to jumper the "A" and "B" terminals of the DLC and then turn the key ON (don't start). Turn key OFF and remove jumper when done.
Be aware that factory fan programming does not turn the fans on until 226º. If you feel that your car is actually getting that hot or hotter, you might have a problem with the temp sensor in the water pump. It is the one that provides info to the pcm. If you have a scanner, you can look at the temp the pcm sees and determine what is going on.
Originally posted by shoebox
That is also one way of testing whether your pcm is capable of turning the fans on. If it does, then all the wiring and relays in the fan circuits are intact.
There are 2 coolant temperature sensors. One goes from the driver's side cylinder head to the gauge on your dashboard. The other goes from the water pump to your PCM.
JR
JR
Man, I read this whole chaper in the Haynes manual on the cooling, heating and air conditioning systems and it doesnt say anything about a sensor in the waterpump... it just tells me about the one on the cylinder head. This book sucks!
but thanks again for your help!
Like shoebox said, you'd need a scan tool that hooks into the ALDL connector under the dash to see what values your sensor is reporting, which would tell you if the sensor has gone bad or not. I don't know if the part numbers for the 2 sensors are the same, maybe you can switch them around? If you swap them, you'd need to drain the coolant. Anyone feel free to chime in here, of course.
JR
PS Let's get some step-by-step pics on that LS1 front end conversion
JR
Another thing thats strange, is that from time to time I get the low coolant level light come one... and when I check my coolant level it is full... what can be causing this?
Originally posted by ReznorZ28
Hey Shoebox, I just got my car back from the paintshop yesterday so I havent been able to troubleshoot until today. I put the relays back in and removed the air pump fuse. The fans do turn on when the SES light comes on. So I gues that means that the wiring and relays in the fan circuits are intact like you said... but where do I go from here?
The low coolant sensor is prone to acting up. Your choices are to remove and clean (possible fix), replace or unplug it. Unplugging it will not cause the SES to come on. The pcm does not monitor this sensor. It will merely disable the light on the dash. Pics of the sensor and replacement info is on my Tech Page.
formula79
26
08-05-2002 12:21 PM
