Help me find this hose PLEASE
I'm desperately looking for this broken hose for my 97 lt1:
I've been searching quite a bit for the correct GM part number for what seems to be the hose marked as 1 in the following diagram:
Does anyone know where I can get a replacement?
Cheers
Cheers
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Help me find this hose PLEASE
The first place to check for part numbers is Shoebox's site. The part number for the hose (which is correct in the above posts) is there.
1993-1997 F-Body Part Number Collection
Thank you guys! I'm not sure about the name or function of that specific part (was searching for "trottle body vent").
Turns out the original owner used some heavy taping to "fix it", and I just found out it was broken while doing some other work.
A bit of oil came out of the hose while removing the electrical tape.
The hose attaches to a hole towards the firewall that seems not 100% sealed (some dry oil is present in the surrounding).
How bad and what could be the consequence of running the car in this state?
The hose supplies fresh, filtered, MAF measured air from a passage in front of and between the throttle blades. The air flows through the hose to the grommeted hole in the passenger side valve cover. There is a plastic elbow that pushes into the grommet.
That air is pulled through the crankcase and lifter valley by vacuum from the PCV valve on the driver side of the intake manifold. If the system leaks air, it means it is bypassing the MAF sensor. Minor lean condition that the PCM can correct based on feedback from the O2 sensors.
Some oil inthe line is not unusual. When crankcase pressure builds when vacuum is low, the crankcase blowby vapor can flow out of the valve cover, entraining oil mist. If you find a lot of oil, it may indicate excessive piston ring blowby.
Good idea to keep the PCV system in good shape.
The plastic elbow that attaches on the throttle body side is the piece that broke. Not sure if part# 10128365 includes it. Can anyone confirm?
I will also replace the grommet at the back since it is not attaching to the valve cover securely.
There is no plastic elbow ar the throttle body. There is a 90-deg bend in the hose, and the end of the hose slips over the larger, upper nipple on the throttle body.
Below the upper nipple, there is a smaller nipple for the plastic line from the EVAP purge solenoid on the bracket on the passenger side of the intake manifold. The small diameter plastic EVAP line connects to a rubber elbow that has a larger diameter that slips over the throttle body nipple. The EVAP line and elbow assembly is discontinued, and can be replicated using a length of hard plastic line from an auto parts store, plus a rubber 90-deg spark plug boot.
Is that possibly the elbow you are referring to?
I was just about to ask about the rubber elbow that you describe. Mine is starting to crack.
Where can we get this part?
Seems like the diamater is different each side of the elbow.
Gotta read what I posted. The EVAP assembly is discontinued by GM. I explained a way to replace the elbow. Many people have done it with a spark plug boot.
If using a spark plug boot isn't to your liking, check ebay. Someone may be selling aftermarket replacements. The Shoebox link has the part # for the complete assembly.
Like Injuneer says try e-bay.They are listed under ( breather hose 1993-1997), and I saw one for $14.99 and another for $27.99.Hope this helps.But I would go to a auto parts store that sells hoses by the foot ,just get the same size.Might be cheaper.
This part # is suppose to be the radiator to coolant reservoir hose.
I ended up not using it since I decided not to mess with the factory crimped hose that sits under the battery.
The Gates' hose works since it has different hole diamaters at each end. One must cut the hose around here to get an air tight fit on the plastic tube's end:
This is how it compares to the original.
Once installed, I was able to achieve an airtight seal on both ends. It's thicker and will stay in place much better than the original.
Cost- around $16 shipped.
Hope someone in a similar situation can save time and money by buying this hose online.
Magenta_Hearts
03-29-2017 08:54 PM
rick350
03-14-2015 10:46 PM
